Speedo Correction
Old 04-03-2011, 03:36 PM
barthel
barthel's Avatar
Default Speedo Correction
Hi All,
I need some help, I've been trying to figure out how to correct my speedometer.
I have a '94 GT convertible with an AODE automatic trans. Axle code is "E" which I'm fairly sure is a 3.27 LS rear end. I'm running 245/45/HR17 tires. As close as I can figure (using 2 different GPS units) my speedo is about 9-10 MPH high, if it shows 8o I'm actually going 70.
Is there a way to correct that by changing the speedo gear, or VSS or something or am I relegated to a speedo calibrator?
Thanks in advance!
barthel is offline
Old 04-03-2011, 08:53 PM
Bubba 95SN
Bubba 95SN's Avatar
Gears, drive and driven control speed of VSS. The drive gear is on mainshaft of transmission and driven gear is on end of VSS>
Bubba 95SN is offline
Old 04-03-2011, 09:29 PM
barthel
barthel's Avatar
Would I replace one, or both? Is there a chart that shows which one would go where?
I don't have much experience with this on a Mustang, but have done this with my Jeep. There's a chart that shows gear ratio and wheel size and corresponds to a colored speedo gear.
barthel is offline
Old 04-04-2011, 03:08 AM
AdderMk2
Banned
AdderMk2's Avatar
your car has aftermarket gears. you need to find out what they are in order to correct the speedo
AdderMk2 is offline
Old 04-04-2011, 07:27 PM
Bubba 95SN
Bubba 95SN's Avatar
Late Model Restoration Supply, Mustang Unlimited, should find chart and part at their site.
mtgldr
02-03-2024 09:00 PM
UrS4
10-03-2015 06:23 AM
69Volunteer
09-30-2015 10:39 AM
ccdguy
09-19-2015 05:20 PM
PNYXPRESS
09-14-2015 09:50 PM
Quick Reply: Speedo Correction
