water pump
Old 08-27-2005, 09:55 PM
crashgoins1
crashgoins1's Avatar
Default water pump
Need a new water pump, need a good one, any idea's, Thanks
crashgoins1 is offline
Old 08-27-2005, 10:57 PM
brutal_gt
brutal_gt's Avatar
Default RE: water pump
im changing mine soon to a edelbrock victor reverse flow. there was a install done for one of the mustang mags out and it got good praises.
brutal_gt is offline
Old 08-28-2005, 12:11 AM
92hatchLX
92hatchLX's Avatar
Ya, get one of the Edlebrock high flow pumps, they're supposed to flow 30% better.
92hatchLX is offline
Old 08-29-2005, 07:51 PM
crashgoins1
Thanks, i'll go with that one!!!!!!!!!!
Old 08-29-2005, 08:35 PM
Quik
Quik's Avatar
i got a summit high flow one. havent had any issues with it
heres a tought for some ppl out there. summit parts arent always summit parts. like the summit 8.8 girdle is actually a TF 8.8 girdle with a different name on it. that also goes with many other things
Quik is offline
Old 08-29-2005, 08:38 PM
stanglx2002
stanglx2002's Avatar
i got a high flow water pump from autozone and it cools my 331 great
stanglx2002 is offline
Old 08-29-2005, 11:06 PM
vfast
I ♥ Acer
vfast's Avatar
all you have to due is change the impellar in a stock one.....I would also change to a 180 MR/gasket stat....you can get them from autozone's web site for 8.00
vfast is offline
Old 08-30-2005, 07:19 PM
sc94gt
sc94gt's Avatar
I just installed a Ford Racing hi-flow from Summitracing.
It was $48. So far it's fine. Autozone wanted $91.
Why do they put that bottom bolt on the water pump right in the way of the crank pulley?
That was kinda of a pain to remove that pulley without removing the fan but I did it.
Take your time and scrape off all of the old gasket before installing the new ater pump.
Get some Hi-temp RTV gasket in a tube (orange stuff) too, for a good seal.
sc94gt is offline
jwog666
12-27-2021 08:09 PM
jerrytubes
10-23-2015 12:11 PM
Bokeo
10-10-2015 08:28 PM
b8checker
10-08-2015 12:55 PM
b8checker
09-30-2015 07:11 AM
Quick Reply: water pump
