help
help
I have a 90 lx car has 30lb injectors 70mm exhaust.car will not idle and seems to be running too rich.Can mass air be calibrated or do I need to put a cam in.what do I need to do to make these injectors work?????
Welcome to the board!
Other than the mods you mentioned, I assume you have an otherwise stock 5.0 in the LX,
I wish I knew the answer, but solution lies in setting the injector operation curve to dump in less fuel where rich and more fuel where lean throughout the RPM bandwidth.
But do check out this link to see how these guys do it:
https://mustangforums.com/forum/5-0l...95-mustang-14/
