95 mustang efi to carb swap
Old 04-10-2011, 09:22 PM
MikeCobb
MikeCobb's Avatar
could i have a bad tps? i have tried the mod to make mine ajustable the spout on my car is located on the passenger side fenderwell when i set base timing with it out set to 10* then i check timing with it in with timing lite timing is over 20*+ and moving around at idle. I have the egr blocked off with a blockoff plate i put it back on just to have something for plug to plug into thinking that could be my problem still no change
MikeCobb is offline
Old 04-10-2011, 10:30 PM
Venomantidote95
Venomantidote95's Avatar
Well if you block ot off dont plug it back in lol. Unplug it and retest. Its possible the tps is bad but not a common on sn styles. U elongated the holes? Whats ur tps voltage koeo with dmm? Needs to be closest to 1volt.
Venomantidote95 is offline
Old 04-11-2011, 05:12 PM
MikeCobb
MikeCobb's Avatar
i ordered a new tps today I will see what it does tomorrow when it comes in and i put it on the car just dont understand why the car runs so much better with the spout out of it just a little sluggish that way revs up good though
MikeCobb is offline
Old 04-11-2011, 06:59 PM
Venomantidote95
Did u even check the voltage? If you just swap parts ur gonna ne in the same boat u were in at the begining stop wasting money unless u know for sure its bad. Thats exactly why the few people who dont like efi dont like it! Ok u swap tps and have the same issue (efi sucks) comes back to play! Get the voltage right knock out one thing at a time. With the spout out chevk timing at about 3000rpm then plug it back in and do the same! Post results! And the tps voltage.
ding56
08-14-2015 02:40 AM
StangMuscle
08-12-2015 07:27 AM
daytooday
08-11-2015 09:22 AM
Jacob4589
08-08-2015 11:00 AM
teeeeg67
08-06-2015 09:41 AM
Quick Reply: 95 mustang efi to carb swap
