Trick Flow stage 2 cam question...
Old 04-10-2011, 05:58 PM
Haze28
Haze28's Avatar
Default Trick Flow stage 2 cam question...
I am new to the pushrod motor game and have been buying up parts for a build over the last few weeks and the last thing I need to get is a cam. I was looking at the stage 2 cam but am wondering if it will be too aggressive for what I have on the car right now.
I couldn't afford a set of heads this year so I basically just bought all of the supporting mods for a decent N/A set up, GT-40 tubular intake, 75mm accufab TB, anderson motorsports 4" power pipe, 255 walbro fuel pump, 30lb injectors, full catless exhaust and a couple other minor things.
I will be adding either a set of twisted wedge or patriot heads next year when I have a little more money. Everything else is stock, 1990 LX 5speed car. What do you guys think?
Haze28 is offline
Old 04-10-2011, 06:22 PM
Venomantidote95
Venomantidote95's Avatar
Aslong as you have the correct springs and are really upgrading heads later then go ahead. But for now its a toss up on the effect u get from the cam could give u false impressions since you dont have the head for it.
Venomantidote95 is offline
Old 04-10-2011, 08:10 PM
93hatch306
93hatch306's Avatar
It'll be a good cam once you add the heads later. With the stock heads, it will sound good but probably kill a lot of low end. I have the same cam with TFS heads and a Holly Systemax intake.
93hatch306 is offline
jwog666
12-27-2021 08:09 PM
patchshaffer
Tuner Central
10-05-2015 02:24 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
junior04
09-28-2015 10:53 AM
09-25-2015 09:06 AM
Quick Reply: Trick Flow stage 2 cam question...
