some good mods to run in the mid 12s
Old 08-28-2005, 05:00 PM
vipjck
vipjck's Avatar
Default some good mods to run in the mid 12s
I just wanted to know if anybody knew what could i do to make my mustang run in the mid 12s.
Thanx
vipjck is offline
Old 08-28-2005, 05:49 PM
JD1969
Pro. B.S. caller outer
JD1969's Avatar
Default RE: some good mods to run in the mid 12s
It helps if you tell us what year/engine/trans you have, also any mods that are already done would help as well.
JD1969 is offline
Old 08-28-2005, 10:45 PM
vfast
I ♥ Acer
vfast's Avatar
race down a steep hill we need to know details
vfast is offline
Old 08-28-2005, 11:03 PM
ZachW04Stang
ZachW04Stang's Avatar
Heres a setup I got from mustang enthusiest that should be good for low 12's.
Stock Short block
Crower "Baby Crower" Cam #15510
Edlebrock Performer RPM Heads
Edlebrock Performer RPM Intake
255 lph fuel pump
24lb injecters
Vortec 73mm mass air
65mm throttle body
3 piece March UDP
160 thermostat
LT Headers 2 1/2 inch exhaust
Flowmasters Cat back
Spark Plugs 2 heat ranges cooler then stock .050 gap
Manual with 3.73 gears
Auto with 2800 stall and 4.10 gears
ZachW04Stang is offline
Old 09-04-2005, 08:50 PM
Syn
Syn's Avatar
a turbo
Syn is offline
Old 09-04-2005, 09:12 PM
cammedlx
cammedlx's Avatar
Easy way.. Free mods,slicks,exhaust,gear and bottle feed that *****....voila 12's
cammedlx is offline
djbigskrilla
09-20-2022 01:04 AM
mstahoo
SVT Forums
08-19-2021 09:15 PM
08-21-2015 12:58 PM
Stilz
08-19-2015 06:17 AM
08-12-2015 05:39 PM
Quick Reply: some good mods to run in the mid 12s
