uneven wear on rod bearings
Old 04-17-2011, 09:11 PM
nightmare90gt
nightmare90gt's Avatar
i didnt want the 5.4 stroke on the boss block cause they made the piston walls shorter for stroker clearance my plans are
boss big bore block
chp rotating assembly with custom pistons to get 9.5:1 compression for later twin turbo setup
trickflow stage 2 cam
get my current trickflow heads ported to 195cc or do you guys think i should go 205cc
hamburger performance 7 quart oil with high volume pump
and cant forget the valve spring upgrade
yes i know i should do a custom cam but i already bought the cam for my motor and i liked the way it performs for an off the shelf cam
nightmare90gt is offline
jrrhd73must
10-02-2015 09:17 PM
KingRando
10-02-2015 08:06 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
UrS4
09-30-2015 10:13 AM
mustangheaven
09-29-2015 11:00 AM
Quick Reply: uneven wear on rod bearings
