ignition switch issues.
Old 04-20-2011, 10:29 AM
minimac
minimac's Avatar
Default ignition switch issues.
So the other day i went to start the car and no lights or anything came on at all, the battery is fully charged and working fine. so i replaced the ignition switch and the lights came on, i put the bezel back together and the lights had gone off, again and when i tried to start it nothing happened. today when i plugged the battery back in the lights came on but very dim, and as soon i turned the key the car went dead again, no instrument panel lights, fuel pump or anything.
minimac is offline
Old 04-20-2011, 06:50 PM
theuniverserewardsaction302
theuniverserewardsaction302's Avatar
Default ignition solenoid
maybe it can be your ignition solenoid with a faulty connection.
I know this sounds dumb but did you make sure the ignition switch was fully snapped in?
theuniverserewardsaction302 is offline
Old 04-20-2011, 09:00 PM
minimac
minimac's Avatar
how do you tell if its snapped in all the way? i mean i bought the switch and left the little bar on it till i bolted it in, i put it in and bolted it down then took the little metal bar off then connected the harness. is there some other way i was supposed to "snap" it in place?
minimac is offline
Old 04-22-2011, 10:39 AM
holyshift
holyshift's Avatar
Theres little tabs on each corner,like a soft metal. Smack them with something to make sure its actually connecting. Had this problem with mine a few years back,turn signals wouldnt work,and if I hit a bump car would shut off,found these tabs werent holding the switch in place. Smacked em down and been good ever since.
holyshift is offline
lincolnshibuya
07-05-2020 03:05 AM
lincolnshibuya
12-08-2015 04:37 PM
bradleyb
11-27-2015 07:50 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
UrS4
09-30-2015 10:13 AM
Quick Reply: ignition switch issues.
