Gas vapor hose???
Gas vapor hose???
Ok, I posted yesterday, and this is a follow up. I did some diagnostic work this morning, and discovered a hose is not connected. Can anyone tell me what this hose is , and if it's the culprit for my problems. I assume it's a gas vapor hose of some sort. See my original post below:
Original Post:
Took a long drive with the wife today with top down - my baby drove like a dream. On the way home (60 miles from home) she started stuttering at about 65 mph. I took my foot off the accelerator, and she died out. I pulled to the shoulder, and tried restarting... no luck. Waited 10 minutes, and she fired up, but I was only able to drive a mile, and she stuttered, and died again. Waited ten minutes, drove about 4 miles, same thing... took me 4 hours to get home repeating this stop and go process over and over again. The last leg of the trip, was the best for some reason... went 12 miles, at 55 mph, and she didn't die once.... so, what's the scoop? Clogged fuel filter is my first guess, and I'll look into that tomorrow. Any other ideas? I was getting some bad fumes while this was going on... almost smelled like the clutch was burning (you know, that sort of smell)... weird, because my clutch is fine...
Original Post:
i can tell you for a fact that hose isnt the problem cause the other day i was poking around under the hood and found that exact hose burned on my header and it looked like it had been like that for awhile.i had no symptoms and when i repaired it car felt exactly the same.it sounds like a fuel pump but do what the other guys said.
Matt's 95 Stang
10-05-2015 07:16 AM
