Oil Leaking From TB need HELP!!
I just got this in a trade.....have a 95 mustang originally a v-6 now has 5.0 out of a 91...has trick flow stage 2 cam, 1.7 roller rockers, gt40 heads from 95 cobra, holley systemax upper truck lower. when i got the car oil was leaking out of the breather oil fill cap(aftermarket) and the pcv was not hooked up.....i bought a new pcv and hooked it up to the front side vacuum port on the upper intake and oil stopped leaking out of the breather......but now ill go for a drive and ill pop the hood and i have oil all over my valve cover and throttle linkage....is this a vacuum problem or something else???
With the engine running, take the filler cap off put a sheet of paper over the hole. If there is pressure the paper will lift, If it lifts you have bad rings or at least 1 or 2 bad oil rings, if it does not lift there is no pressure so no bad rings , get a new filler cap.
