clutch problems
Old 08-29-2005, 10:22 PM
ballzoutstang875.0
ballzoutstang875.0's Avatar
Default clutch problems
I was driving my stang the other day and lately, the shifting has been really stiff. I actually pulled my clutch pedal back as far as it would go, thinking that it was just bent because i have to put the pedal to the floor to shift, and for a few days, it seemed to have fixed the problem- it was shifting really smooth, the way it should. well, a few days later, the pedal lost most of all its pressure and wont go into any gear at all while the car is running- obviously it will go into gear while the car is off. im having a buddy take it apart but we dont have a clue on what to look at. I thought that pulling the pedal would have stretched the clutch cable, but it seems to be fine. we think its something in the clutch- maybe the throw out bearing?? any other suggestions would help alot...
ballzoutstang875.0 is offline
Old 08-29-2005, 11:46 PM
93BlackSunshine
93BlackSunshine's Avatar
Default RE: clutch problems
you probably have the stock clutch quadrent.. that might be the problem, because when you pull the pedal on the stock quad... it ratchets the plastic. and the piece is probably stirpped... and thats why it may have worked for a few days.. so get yourself a steeda clutch quadrent double hook.
93BlackSunshine is offline
Old 08-30-2005, 09:41 AM
stanglx2002
stanglx2002's Avatar
ORIGINAL: 93BlackSunshine
i agree its time to upgrade to a clutch cable kit and IMO i say to get the kit that has a firewall adjuster too
stanglx2002 is offline
Old 08-30-2005, 03:34 PM
soccerm_d
soccerm_d's Avatar
Yes you definitely need to get an adjustable clutch cable.
soccerm_d is offline
Old 08-31-2005, 12:01 AM
ballzoutstang875.0
ill check into the quadrent but it seems to be ok, if u know how the quadrent works, the further down the clutch is, the harder it is to shift. on mine, if u take the pedal and pull it up to the last notch, it "used to" shift good, which makes sense that the quadrent might be bad, but, it will still catch its self on the notches. i was wondering if maybe the shift fork could have come off the pivot?? also, is the clutch quadrent a dealer item only? what are the chances of that being the problem 'cause i dont have a clue on where to begin here if its not the quadrent-which ill check in on that tomorrow...
Old 08-31-2005, 09:48 PM
ballzoutstang875.0
anybody please....help. ive got the dash out right now... looking at the quadrent. whatever else is down there.
Old 08-31-2005, 11:34 PM
stanglx2002
feel the quadrant to see if the notches are still there or are stripped off
AmericanMuscle4.6GT
11-10-2015 02:06 PM
MasterLanMan
09-13-2015 08:21 PM
Brandonfilipponi@yahoo.com
09-12-2015 11:39 AM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
Quick Reply: clutch problems
