Quick c4 trans question.
Hi guys i just finished rebuilding my first c4 trans. My question is i just installed a deep sump hughes pan.
Now do you need to have a drop filter installed or can i use just the stock filter? I'm using a tci full manual vb. Hope someone can chime in. What line size would you recommend using for trans cooler? 5/16? 3/8?
thx for any help in advance.
Just make sure you have enough fluid in there. Your dipstick may not be accurate now. I learned the hard way,when I launched the car right before 60ft it would flash like it was in neutral. What was happening was I didnt have enough fluid and when i launched it would all rush to the back of the pan away from the filter causing the flash....I even bought a new converter thinking that was the problem....oh well. Live and learn.
yourmom6990
3.7L V6 Technical Discussions
10-14-2015 10:08 PM
