Electrical Problem
Old 08-29-2005, 11:30 PM
JohnChule
JohnChule's Avatar
Default Electrical Problem
Windshield wipers dont work(changed motor) Slow blinkers, and i have to pull back on the headlights lever and hold it for the lights to be on, i know its all in the instrument cluster but what do you guys think is causing it so i know what to look for?
JohnChule is offline
Old 08-30-2005, 12:04 AM
90GTRagtop
90GTRagtop's Avatar
Default RE: Electrical Problem
What year? Have you checked the voltage when it's running (should be around 14½ to 15½)? You could look at the wiring diagrams at Autozone.com
90GTRagtop is offline
Old 08-30-2005, 12:41 AM
settled4automatic
settled4automatic's Avatar
so you have to hold back on the lever on the column for your headlights to work?? if that's the case... its that multifunction switch in the column that's failing. i wired up my own lil switch for headlights in my 87, because i had to hold that lever back when i first bought it. wiring diagrams are easy to use if u wanna do an afro-engineer job about it. and are your blinkers like REALLY slow? slower than normal? because they're known to be slow in the foxes.
settled4automatic is offline
Old 08-30-2005, 01:13 AM
JohnChule
JohnChule's Avatar
Hey i wired a switch too cause i was getting tired of holding the lever back. The blinkers are slower then they used to be. Plus the wiring for the windshield wipers is messed up because the motor is fine but they still dont work.
Old 08-30-2005, 01:14 AM
JohnChule
JohnChule's Avatar
Its a 89 GT
Old 08-30-2005, 09:51 AM
stanglx2002
stanglx2002's Avatar
first check all your fuses and if they are all alright then its your multifunction switch bc it runs all those parts. also what is your voltage at when the car is running is it at least half way on the gauge
stanglx2002 is offline
Old 08-30-2005, 07:07 PM
90GTRagtop
90GTRagtop's Avatar
I agree with the others. If your voltage is OK, it sounds a lot like the multifunction switch. You'll need to replace it.
Old 08-30-2005, 10:58 PM
JohnChule
JohnChule's Avatar
ORIGINAL: stanglx2002
Its always really low like around 8 volts.
jma2
07-10-2023 01:00 AM
ak98
02-18-2023 08:36 AM
uberstang1
09-20-2015 06:42 PM
ccdguy
09-19-2015 05:20 PM
TfcCDR
09-14-2015 12:08 PM
Quick Reply: Electrical Problem
