mechanical gauge confusion!!!
Old 05-08-2011, 10:03 PM
86 newbie
86 newbie's Avatar
Default mechanical gauge confusion!!!
ok so i got a 86 5.0 stock 5-speed. my dad has a mechanical water temp gauge that hes letting me use. so i drilled a hole in the fire wall and ran it to the hole in the block where the sender unit was. now, the bolt that's on the original mechanical thermostat gauge is too small for my hole in the block. it will screw down but its loose and it would never work. i went to lows and got a bolt that has the hex part in the middle and the rest is threaded and it is 3/8 because that's what i was told fits the hole for the block. then i got a coupler for the other end of the bolt and its so the original thermostat bolt will bolt on which it does but the other end that goes into the block is too big. i think it has to deal with the whole metric crap. so can you guys tell me how to fix this??
86 newbie is offline
Old 05-08-2011, 10:17 PM
tohoopty
tohoopty's Avatar
you need to learn what parts you are talking about and come back when you can clearly tell us what your talking about
tohoopty is offline
Old 05-08-2011, 11:28 PM
AdderMk2
Banned
AdderMk2's Avatar
I know... right
Holy crap!
AdderMk2 is offline
Old 05-09-2011, 10:26 AM
86 newbie
86 newbie's Avatar
im gunna post a pic because i cant explain stuff very well
Old 05-09-2011, 10:01 PM
86 newbie
86 newbie's Avatar
nvm i got the part from jegs, it was a mechanical gauge adapter that i needed
jwog666
12-27-2021 08:09 PM
4cylinderplus2
10-09-2020 07:45 PM
lincolnshibuya
07-05-2020 03:05 AM
wraith777
09-28-2015 10:49 AM
mrappe
09-26-2015 10:16 AM
Quick Reply: mechanical gauge confusion!!!
