91 Fox 5.0 Question-Ignition
Old 05-10-2011, 03:01 AM
Stockstangs
Stockstangs's Avatar
Default 91 Fox 5.0 Question-Ignition
On the way home today my Fox died at 70m on the highway. I dropped it down to another gear and it started back. It ran for about 5 minutes. It started running real rough. I pulled over let it sit for a few minutes, started it back up it ran ok for a minute then started loosing power and running rough eventuallt cutting off. It did this numerous times, let sit for a few, cranked up ran ok at first then rough running eventually dieing. All the guages are reading fine- not overheating. I was wondering what you guys think? I thought the fuel pump at first, but if it was bad wouldn't the car not start at all? It is engaging when I cut the switch on. I also thought it may be the ignition coil. Maybe going bad? Any help or advice would be appreciated. Thanks-
Stockstangs is offline
Old 05-10-2011, 07:09 AM
nitrous_bob
nitrous_bob's Avatar
dizzy module ?
nitrous_bob is offline
Old 05-10-2011, 03:11 PM
Stockstangs
Dizzy Module ???? I think I have it figured out- wire running from the coil to the distributor was not making contact completely. So far ok. Thanks.
Old 05-18-2011, 08:28 PM
mgmuscari
mgmuscari's Avatar
I think he's referring to the fact that the TFI module on the distributor can start to misbehave under heat when it's getting ready to fail.
mgmuscari is offline
Urambo Tauro
10-05-2015 09:37 PM
Matt's 95 Stang
10-05-2015 07:16 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
RCS02v6
09-29-2015 01:46 PM
Quick Reply: 91 Fox 5.0 Question-Ignition
