GT 40p Heads
GT 40p Heads
Will GT 40p heads work with bbk equal length headers? I know they don't work with all headers but I saw they worked with the bbk shorty headers so I wasn't sure. Not going to buy them if i'm going to have to spend a bunch of money on new headers so figured i'd make sure first. If it makes any difference I have a 95 GTS
from what I have heard, the gains from equals to unequals is minimal if any and not worth the cost. Not sure if that is right as I am not a motor expert but when I was looking for headers that is what I was told.
from what i hear, the difference is the spark plug angle, imo, id would say they should work, i know with some lt headers guys were having issues cause the headers have to fit closer to the block so they can find there way down underneath the car. but as for a shorty header equal or unequal, id say you should be fine.
I did some more searching and found some stuff saying that if I got a shorty spark plug it would work (only need it for one of the spark plugs) and then spark plug wires at a 90 degree angle that those would give me the clearance. I also read that the MSD wires have bendable connections, is this true? Then I could just bend them so I could have the right clearance?
I doubt it with equal length. I have the un-equal bbks on mine and they work fine. I did have to put a 90 degree spark plug boot on number 7. My wires are MSDs and I still had to use the 90 degree boot on number 7. The do bend but, they won't make a turn like a different plug wire boot will.
