Oil Pump Shaft
So I contacted my engine builder, sent him pics of what I found, and he had me cut my oil filter open and send more pics. He admitted it must have been a mistake on their part, to not put the plug in, and offered to send me a new short block and gasket set IF the bottom end was toast. After sending the pictures, he was convinced I was ok. But wanted me to keep in touch.
I have put over 5k miles on the engine since (not very nice miles either) and it still runs fine! I did have the opportunity to change out the thrust bearing though (over tensioned clutch cable). While I had it out, I took a few more pics and sent them to my builder, and he said that there shouldn't be any issues with the oil pressure problem it had.
I have since removed and sold the cam that was in the car at the time, and it didnt show any signs of scarring from no oil pressure... but then again, I used a ton of assembly lube on that too!
The bearings can take a beating and still be fine. The first time my 83 was started up with the motor I have now it didn't have a oil pump shaft at all. This was before I really new much about the motor and my brother assumed it had one since it was a running motor and we never removed the oil pump. We ran it for about 30 seconds with absolutely no oil pressure. I drove the car all summer and when I tore the motor down the winter of 08 the bearings still looked good. I am still running the motor today...with a bent crank.....with 25-60psi of oil pressure all the time depending on the RPM.
Boostaddict
2.3L Eco-Boost Tech
11-24-2015 06:11 AM
mrappe
09-26-2015 10:16 AM
