TemP gauge help please
Old 05-29-2011, 08:10 PM
g3mustang
g3mustang's Avatar
Default TemP gauge help please
So I took off my upper intake to change injectors and after put back togeather I noticed that my temp was rising higher then normal but slowly. So I checked radiator everything seemed to be fine. I was testing the temp with headlights off normal temp turn lights on temp creep ups weird!! So I replaced the sending unit but now my temp read lower then used to. In-between the a and the l. But if I turn the headlights on starts to creep again. What gives. All grounds are still hooked up. Some one put a 140 speedo in the car before I had it. If that gives any info.
Thanks for the help
g3mustang is offline
Old 05-29-2011, 08:22 PM
7gtthrilla
7gtthrilla's Avatar
I wish i could help, but that's the strangest thing that I've ever heard. Not sure what the problem could be. Good luck!
7gtthrilla is offline
Old 05-29-2011, 09:32 PM
AdderMk2
Banned
AdderMk2's Avatar
not all sending units show the same resistance for the same temp ranges.
You are just going to need to get used to it.
AdderMk2 is offline
Old 05-29-2011, 10:07 PM
g3mustang
g3mustang's Avatar
Ok thanks for the advise!!! Should I buy a motor craft one from 50resto instead of the autozone I got think that would help
Old 05-30-2011, 12:07 AM
lafd5246
lafd5246's Avatar
My headlights affect the temp gauge also, and I have seen A LOT of people with the same issue. I heard someone say it sound like a ground in the cluster. The most common advise I have seen is to get a good aftermarket gauge. I have learned to live with the problem and spend my money on other mods, for now.
lafd5246 is offline
Old 05-30-2011, 03:07 AM
Dj_Seph
Dj_Seph's Avatar
Aftermarket gauge is your friend. One of my favorite mods done so far.
Dj_Seph is offline
jwog666
12-27-2021 08:09 PM
andrew1969
16
01-08-2016 02:48 PM
SteelerNation82
09-16-2015 07:11 AM
Pyrate Dave
09-10-2015 07:30 PM
96stang3.8
09-10-2015 06:42 AM
Quick Reply: TemP gauge help please
