3g alternator
RE: 3g alternator
If you bought a PA amp then it should have come with instructions that are full proof. I bought a 3g 130 alt 2 weeks ago and installed it in an hour or two. Was so easy with the instructions.
But if you didn't get it then basically you have to take the old alt out. Cut the harness off the alt that has the two black/orange wires on it. The new harness will attach to that. Plug it up and install the new alt with some bracket modifications for the alt to fit.
BUT MAKE SURE....that you add another or larger power wire from the alt to the batt. The 130 puts out so much amps that you need a larger wire. I just added a 4awg power wire that went strait from the alt to the batt.
I know there are some details I left out but I'm not home right now to see that instruction paper.
I have pics too.
NOTE::: just read that it was a 95. I think it should be the same but check out www.pa-performance.com ( i think that is the website and they should have their instructions on there for their alt. Should be the same I think.
I have pics too.
RE: 3g alternator
Just found this......
http://www.fordmuscle.com/archives/2...ce/index.shtml
Check it out...I didn't read it but looks like it can help.
Golfsito
10-06-2015 11:02 AM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
