1990 Mustang Electrical Problem with Starting
Old 06-02-2011, 09:59 PM
RMBillings
RMBillings's Avatar
Default 1990 Mustang Electrical Problem with Starting
I really need some help with a electrical problem I am having with my 1990 LX
5.0 mustang. When I started the car the engine started but the starter did not stop running. Even after I turned the key off the starter would not stop running until I disconnected the battery. After about 10 minutes I tried to reconnect the battery but then the starter kicked in again.
After I replaced the starter everything worked for a little while but then tonight it did it again. Does anyone have any idea why this is happening? Or how to fix it?
Any help you could give would be great.
RMBillings is offline
Old 06-03-2011, 02:41 AM
1990boostang
1990boostang's Avatar
Starter Solenoid.. Located on the driver side right behind your battery.. About 14 bucks at your local parts house....
1990boostang is offline
Old 06-03-2011, 07:27 AM
RMBillings
RMBillings's Avatar
I changed the Starter Solenoid at the same time as the starter and it did not help.
Old 06-03-2011, 05:29 PM
fltt
fltt's Avatar
Hooked the starter solenoid up wrong? Or Check your ignition wire going to the starter solenoid and see if it stays hot after the crank cycle.
fltt is offline
Old 06-03-2011, 07:48 PM
RMBillings
RMBillings's Avatar
I have checked it mutiple times and the selonoid is hooked up correct. The wires don't get hot until after the problem starts.
Old 06-03-2011, 08:14 PM
Bubba 95SN
Bubba 95SN's Avatar
Ignition switch.
Bubba 95SN is offline
Old 06-04-2011, 05:29 AM
fltt
fltt's Avatar
Agree with ignition switch
fltt is offline
Old 06-05-2011, 11:49 AM
atomicboom21
atomicboom21's Avatar
i have a question. my 1990 5.0 lost power and died on me and shot something out my cat and left a nice size hole. the Battery light and the check engine light came on and now it wont start.
atomicboom21 is offline
KEM Motorworks
08-14-2015 10:13 PM
drumhedd2005
08-13-2015 09:59 AM
daytooday
08-11-2015 09:22 AM
89blueslug
08-10-2015 07:20 AM
Pain.
08-07-2015 10:48 PM
Quick Reply: 1990 Mustang Electrical Problem with Starting
