12v Start/Run source
89 GT here, are there any fuses in the fuse panel that are hot in the start AND run position but dead when the key is off? I have a switch panel that needs power is those 2 positions and I bought an add a circuit but am unsure where to put it. Current draw is minimal, maybe 3 amps.
I doubt it. I could be wrong though, so you can test each circuit with your multimeter.
You could wire it directly to the battery (or solenoid post) for constant power. You'd have to remember to turn it off each time though.
Or run two wires to it, one that is powered by a switched source, and a second that is run from the switched side of the starter solenoid. Be sure to have a diode on the switched wire you run so you don't run juice from the starter solenoid back up the switched wire.
I remember seeing a diagram saying #18 is hot in start and run, maybe someone can confirm this. I really dont want it hot at all times but if i have to i will. The 2 wire idea won't work because one of the switches needs power in run and while cranking, not one or the either.
Here's the panel:
Fits where the ashtray was, top 2 control fuel pump and mallory box and the bottom is a 3 way for my Taurus fan.
Here's the panel:
I do grant you that this method is a bit of a kludge, and there is probably a better way.
I was in Waterbury Center. I really liked the slow pace of life there, which is completely different from Orlando. I'll get back to the snow in a year or two, once I am done with school. I fell in love with the Rockies when I went skiing out there 20 years ago so that is what I am shooting for now.
Here's the panel:
Here's the panel:
breaking
10-02-2015 01:27 PM
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
