Turn signals and hazard lights not working
Hey i need some advice, my turn signals and hazard lights quit working the other day. My wipers and highbeams still work. I replaced the multifunction switch and i still have the same problem. Any ideas as to what i need to do?
Here is a link to wiring diagram.
http://www.veryuseful.com/mustang/te...r-Lighting.gif
Check your fuses. If they are all good then find your flasher and see if it has power in and power out. if no power out change the flasher.
I have a 2006 v6 . Where is the flasher and the turn single relay located. I can hear them. I have been all over the dash. Fuse panel on the passenger side and the main power under the hood. Maybe its part of the PCM. if so can you replace that part or just a new PCM?
I'm only a two day owner.
Thanks
Mac
Thanks
Mac
