Strut won't come off!!
The PS side came off in 1 second, but he driver I spent 2 hours and it wont budge. The Ds side has no square edge to hold the strut while you loosen the nut. I've bout a nut splitter and a nut chisel and ive gotten no where.
I've never said this, but Im about done with fords BS, plus this is the slowes the ****en car. Ive had neons, eclipses and camaros leave me in the f'en dust!.
I can't help it, im over a car the get beat by chevy suburbans.
Sounds like you need to learn how to drive your car and also realize that most cars on the roads nowadays have more power and torque with alot less displacement....
Its called air tools....never had an issue with the nut. How are you going about removing them?
I'm pretty sure the driver side strut in OE, since it has no square end on it.
what do you expect from a stock mustang?? you have no real mods, can't expect a 20 year old ride to still compete with the new technology that is now out without adding some yourself.
That a good idea to just remove the whole strut, so i can have somewhere to hold it.
Even the new struts had the square, but as you guys have stated, theres other ways to get it off.
I have a reciprocating saw, would i have enough room to cut the bolt underneath the strut mount?
I am not sure where you mean. I cut a line through the top strut bolt. My friend was holding the strut so it wouldn't just fall out. Just be careful not to cut into the metal bushing that is under the bolt.
