Radiator cooling fan question - MustangForums.com
Old 07-21-2011, 09:15 PM   #1
mcblckb
Default Radiator cooling fan question
I have a 1994 GT with a stock 5.0. I'm wanting to install an aluminum radiator with two cooling fans. Currently i have the factory one cooling fan. Is there a way to install the two fans with the existing wiring? If not how would i wire it?
Any advice is much appreciated, as i'm new to all of this. Thanks!
mcblckb is offline   Reply With Quote
Old 07-21-2011, 10:02 PM   #2
nitrous_bob
nitrous_bob's Avatar
is your new rad a 3 core ? or 2 core ?
is your t stat still a 192* or whatever they are ?
honestly...if the new one is 3 core, do a 180* and call it a day
you'll be fine
nitrous_bob is offline   Reply With Quote
Old 07-22-2011, 08:59 AM   #3
mcblckb
The new rad is a 3 core. I put a 185 degree theromstat in it. Its been running a little hot when idleing and the only thing i haven't replaced is the rad. I didn't know if getting the two fans and creating a push pull action would help more than just the one fan or not.
Thanks for the advice!
Old 07-22-2011, 02:15 PM   #4
AdderMk2
Banned
there is no point to replace the fan with any kind of aftermarket unit, as long as it still works. The SN-95 fan is far superior to most aftermarket fan setups. If you car is overheating at idle you need to verify that the fan is working, and make sure your water pump isnt dead.
AdderMk2 is offline   Reply With Quote
Old 06-17-2013, 12:38 PM   #5
geepwar
my radiator cooling fan runs all the time. I unplug the temp sensor and it still runs. could it be the CCRM?
geepwar is offline   Reply With Quote
Old 06-17-2013, 02:31 PM   #6
dawson1112
Quote:
if your fan runs all the time that is ususally a symptom of a bad engine coolant temp sensor or the wiring going to it. If you unplug the sensor it will run all the time by default. So if the ecm isn't seeing the sensor the fan runs.
dawson1112 is offline   Reply With Quote
Old 06-17-2013, 02:33 PM   #7
dawson1112
what do you consider "a little hot "
What is your timing set at, advancing the timing will cause it to run a bit hotter than usual. Advancing way to far will cause it to over heat.
Old 06-17-2013, 08:37 PM   #8
BabyGT
BabyGT's Avatar
Way to drag back a year old thread you two lol. I doubt the one guy is gonna answer.
BabyGT is offline   Reply With Quote
Old 06-18-2013, 06:11 PM   #9
mcblckb
It was a cracked head. The crack was to small to notice any coolent leak, but failed a pressure test. Replaced the heads and now she runs like a dream.
QUOTE=dawson1112;8232806]what do you consider "a little hot "
What is your timing set at, advancing the timing will cause it to run a bit hotter than usual. Advancing way to far will cause it to over heat.[/QUOTE]
2015 Mustang Expansion Tank Granatelli Sales The New S550 2015-2016 Mustang 15 06-23-2016 06:26 PM
I'm selling my Trans Am. GStam66 Off Topic 42 09-26-2015 11:06 PM
Tuner/air intake dealer service question 04stangman 2005-2014 Mustangs 4 09-17-2015 02:45 PM
01 Mustang Overheating :( MusicCity615 General Tech 7 09-12-2015 08:05 AM
HELP.. Should I buy this fox? raleigh05GTO New Member Area 5 09-04-2015 08:09 AM
2011, 95, changing, clip, cooling, engine, fan, fans, ford, gt, mount, mustang, put, radiator, v6
