When a dyno tune is most effective?
Old 07-25-2011, 07:18 PM
92Philly5.0
92Philly5.0's Avatar
Default When a dyno tune is most effective?
Hello All,
I am currently running Flowmaster 40 series catback, Off Road H-pipe, BBK Shorty Headers. 4.10 Gears, CAI and an aluminum drive shaft. Seems to be running a bit lean. I would like to get my most bang for my buck so I'm just throwing this out there. Is there anything else I should do before I spend the money on the tune?
Plus any recommendations of a dyno tuner in the philly area would be great! Thanks everyone
92Philly5.0 is offline
Old 07-25-2011, 07:22 PM
92Philly5.0
Also have a full MSD 6AL Ignition setup, distributor, wires, blaster that hasn't been installed yet.
Old 07-25-2011, 08:12 PM
rtintwo
rtintwo's Avatar
Why do you think its lean what are your symptoms? You havent made any mods that would lead to a lean condition so if you are lean then it needs to be troubleshot. To dyno tune without troubleshooting would just hide a problem if you do have one. Dont put the ignition on until the possible problem is troubleshot.
Dyno it only when you are certain you are at 100%. And to be honest you havent listed anything that would require time on a dyno. Everything listed is just bolt on and not major mods. Save your money and put some more gas in the tank.
rtintwo is offline
Old 07-25-2011, 08:37 PM
uedlose
uedlose's Avatar
a dyno tune for you would be a waste of $$$$ IMO
uedlose is offline
Old 07-25-2011, 09:52 PM
Bubba 95SN
Bubba 95SN's Avatar
To do before dyno tune...HCI
Bubba 95SN is offline
Old 07-25-2011, 10:25 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
what makes you think it's lean?? if it is a koer test will say so, run one lately??
mjr46 is offline
Old 07-25-2011, 11:08 PM
AdderMk2
Banned
AdderMk2's Avatar
Clean your maf, any lean symptoms will go away.
AdderMk2 is offline
Old 07-26-2011, 02:53 AM
92Philly5.0
I was under the impression that the more mods you do pertaining to forcing more air, the more lean the engine got. I haven't checked the plugs yet or cleaned the maf so I'll start there. I just remember when I did the exact same mods to my mach it was pinging all over the place and the dyno tune found about 30hp. I am no expert by any means, the car just feels like its starving for something when I get on it.
Old 07-26-2011, 03:18 AM
AdderMk2
Banned
AdderMk2's Avatar
You haven't done any mods that "force more air". This is also not "your mach". The foxbody GUFx ECM's are a very VERY flexible system. Your maf measures the air that enters your engine. The ECM has been programmed for the flow values of your MAF and your injectors, and will constantly tweak itself based off the readings from your O2 sensors.
So if you truly think your car is lean (even though you haven't even checked). You should clean your MAF, check for vac leaks, and replace your o2 sensors.
AdderMk2 is offline
Old 07-26-2011, 11:38 AM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
Also, sell your MSD dizzy and coil because you don't need them. The stock system works perfectly fine. The stock coil actually out performs most aftermarket coils.
projectresto83 is offline
Quick Reply: When a dyno tune is most effective?
