alternator pulley
Old 07-27-2011, 10:12 PM
load1234
load1234's Avatar
Default alternator pulley
I have an 86 that eats alternator pulleys. it seems like there is too much pressure on the belt, thus putting pressure on the alternator pulley and it is augering out the middle of the pulley eventually causing the belt to come off. the tensioner says it is within limits but i have gone through 3 different pulleys. it is an ac car with the smog pump still on it. any help would be appreciated.
load1234 is offline
Old 07-28-2011, 08:37 AM
rtintwo
rtintwo's Avatar
Take a look at the pulley from the side. Does it look like the pulley is in alinement with the othe pulleys or is it sitting a bit out of alinement?
rtintwo is offline
Old 07-28-2011, 09:45 AM
nitrous_bob
nitrous_bob's Avatar
wheres the mark on the tensioner at ?
nitrous_bob is offline
Old 07-28-2011, 10:04 AM
load1234
load1234's Avatar
the last time it happened, i bought the heaviest duty alternator i could find, it has a pulley with a full shank, not like the stock one. the pulley is in alignment with the others and the best way to describe what is happening is it is putting too much pressure seems like on the belt side so it is basically making the original round hole into an oval and losing tension. the tensioner indicator shows pretty much right in the middle, maybe on the high side.
load1234 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
4cylinderplus2
10-09-2020 07:45 PM
spdeplayer2
10-24-2015 09:45 AM
Golfsito
10-06-2015 11:02 AM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
Quick Reply: alternator pulley
