boost gauge
boost gauge
I hooked up a boost gauge to my car to see how much boost the motor was gettin and it read about 16 to 20 Vac and when I get on it it will drop to zero and I am not reading any boost ... 6 inch bottom pulley and 2.90 top. I have checked the meter out with low pressure air about 7 lbs from my compressor and it shows the same , any ideas would be great , I looked for post on this site but didnt find any ...
^^^kinda obvious OP...
Boost leak test needed....
Ignore the car and the guys doing it but pay attention to what they are doing
http://www.youtube.com/watch?v=atretf9u-Mc
Then Obvioulsy also triple check all of your vac lines and the plastic tree on the firewall
Thanks for the vid.. I have to agree that I have to good of vac to have a vac leak I will check for a boost leak .. wish I could post a pick, I do not have a inter cooler, goes from charger to intake 1 pipe 2 fittings ....
Wow, that's really weird that you have good vacuum and no boost, if you had a leak I'd think it'd be obvious with your set up being so simple like that. I would also check your S/C belt. Sometimes it's the simplest thing!
