CLay Test for Valve clearance
Old 08-02-2011, 01:18 PM
tank86
tank86's Avatar
Default CLay Test for Valve clearance
i keep hearing about doing the clay test for valve clearance, but have "googled" it and found nothing. do u just put clay on the valve covers and see if there is an imprint?
tank86 is offline
Old 08-02-2011, 02:07 PM
AdderMk2
Banned
AdderMk2's Avatar
lmao.. not even close bro.
"Claying" the valves refers to a method of checking piston to valve clearance. This involves removing the heads. If your engine is currently running, you DONT need to check your PtV
AdderMk2 is offline
Old 08-02-2011, 02:44 PM
tank86
tank86's Avatar
I was considering new heads but was told to check clearance and was curious on how to perform this clay test
tank86 is offline
Old 08-02-2011, 02:48 PM
tank86
tank86's Avatar
Btw I apologize for the stupid question I've never torn apart an engine and I'm doing everything by reading forums books etc. Germany is a bad place to learn
tank86 is offline
Old 08-03-2011, 08:43 AM
AdderMk2
Banned
AdderMk2's Avatar
you shouldnt attempt to install new heads on your 86 short block. The flat top pistons will not work well with inline valved heads. Consider a shortblock rebuild with new pistons before anything else.
AdderMk2 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
mrtrodonet
09-19-2020 03:12 PM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
Florida Regional Chapter
09-30-2015 08:04 PM
GT350 S550 Tech
09-29-2015 03:29 PM
Quick Reply: CLay Test for Valve clearance
