no power
instead of being a dip****, maybe you should understand what I'm saying. Go to www.veryuseful.com and look up the wiring schematics for your car. Start from the battery and work your way back from there.
Holy ****! How are your terminals, is your ground tight? Did you check for voltage at the solenoid? did you check for voltage at the fuse panel? These are simple questions, which you shouldn't need to ask about. Start from a known, and work towards the unknown.
ADDER
KingRando
10-02-2015 08:06 AM
09-25-2015 06:58 PM
