Master cylinder bore size
I'm installing an SSBC 4 wheel disc brake kit on my 93.
It's a complete kit with all the needed hardware, lines, proportioning valve etc.
Problem is it also comes with an 81 - 86 Ford LTD master cylinder. It has a 25.4mm bore.
It's a large capacity ugly cast piece that I do not want to use.
Hoping to find a modern aluminum master cylinder with the plastic resorvoir if you know of an equivalent in function master that will work.
That's a 1" bore.
The 93 Cobra used what you're looking for, DORMAN Part # M390125, $57 , OR CENTRIC Part # 13061060, $64, at Rock Auto.
Be sure to get a rear disc specific master so you get the right bias in the piston.
AmericanMuscle4.6GT
11-10-2015 02:06 PM
