new motor, new clutch
I have a 94 gt that i am about to put another motor in. I have a quetion or 2 before i pull the old motor out. The motor I'm putting in came from a 92 model gt, has a trickflow topend kit. The guy built a 393 windsor so i bought the whole motor centerforce clutch and other small things from him. My question is, will the centerforce clutch disk and pressure plate work in my 94gt, z spec trans that i bought from promotion performance?Do i need to buy a throw out bearing to match the clutch or the trans? And since i'm using my accessories, will i be able to use my underdrive pulleys or do i need the 92 model underdrives? I'm sure this has been done before, but i cant find a post right off. So any help is appriciated!!!
swap everything off the front of your engine, onto the engine from the 92. i mean everything!
Timing cover, Accessories, Water pump.... everything. As for the trans, the clutch you have will be fine, unless his car used a 26 spline input shaft on the trans.
and wile youre at it, put the stock pullies back on... UDP's = joke
timing cover too? doesnt look different but, i havent got my motor out yet either. I was going to get a new water pump anyway, so no problem. And as far as under drives.... their so purty!!! But with the alternator dropping low voltage while idleing, I already thought about ditching them too. So I should get a matching centerforce throwout bearing for the 92 clutch and it'll work?
junior04
09-28-2015 10:53 AM
logan409
09-26-2015 07:43 PM
