possible heater core issue?
I just got off work and when I drove home I parked I noticed steam from the passenger side of my hood. When I popped it, I noticed a small drain tube from the lower section of the fire wall dripping onto my exhaust. Only thing I can figure is the heater core sprung a leak and ford engineers were concious enough to not let it spill all over the floor. Am I on the right track?
if you had a heater core leak you would have a we floorboard, not a leak on the header. Sounds like the seals going to the heater core might have gone out and need replacing but they are alot easier then the core itself.
theres a drain on the firewall for them to leak out of.mine did the same thing
ttocs, as I mention I would have expected a wet floor board, but theres nothing else that makes any sense for this drain tube. What I find surprising is that at least one manufacturer was thoughtful enough to do this.
There is always a drain tube for *any* moisture that accumulates in the HVAC housing. When running the AC for example. (ever see a wet spot on the ground a hot day when running the AC and parked? ;-) )
The reason some guys get a wet floor from AC use and/or a leaking heater core is because this drain tube is plugged up.
