t-5 transmission changes,
Originally Posted by Buzzstang
mine was custom. i just made them work.
I always wondered why the used GM front drivers were so much cheaper than the rear drivers. I almost bought one for a swap source on a rwd car-glad I called an engine shop first! </P>
Okay guys thanks for the help. I found some more information on the gear ratios and such. Buzzstang: Ive got some questions about the swap for you. do you have aim? Also, did you turn the intake around (so its facing the timing covers)?</P>
can i use any t-5, even out of a chevy? Obviously ill change the bellhousing. </P>
</P>
</P>
Originally Posted by johnc
Well....Ford did make an all wheel drive Aerostar minivan. It had an IRS front end. I only saw one, and that was a while ago. Dunno if you could graft the drivetrain to a 'stang. </P>
Any pictures or specs on this car ?</P>
I donno if its the same, but ford did make a concept aerostar with a sho motor. just have a few pics, no specs on it other than the fact it wasa 5spd MTX. </P>
</P>
</P>
</P>
</P>
</P>
that thing is sweet! </P>
btw superduty, i want your junk sho! <IMG src=smileys/smiley14.gif border="0"></P>
I know they made a Ranger SHO but never a van. Are you sure you dont mean the Ranger ?Some people also made like a SHO wagon. If you didnt live in NY it would be cool but I gotta get rid of this thing
yeah im sure. thats a 1995 concept van. Im actually in the process of doing a showagon right now. Its actually not very complicated. You can swap the entire powertrain and subframe from a SHO. Everything bolts up. The shifter is going to be a POS. Where are you located in the US. I can travel ya know! </P>
silas</P>
