TF stage2 cam clear ported gt40P's?
Old 09-30-2011, 01:29 PM
88GTBLACK
88GTBLACK's Avatar
Default TF stage2 cam clear ported gt40P's?
Intake Duration at 050 inch Lift 224
Exhaust Duration at 050 inch Lift 232
Duration at 050 inch Lift 224 int./232 exh.
Intake Duration 293
Exhaust Duration 290
Duration 293 int./290 exh.
Intake Valve Lift 0.542 in.
Exhaust Valve Lift 0.563 in.
Valve Lift with Factory Rocker Arm Ratio 0.542 int./0.563 exh. lift
Lobe Separation (degrees) 112
I'm trying to make it happen with this setup. I have a Stage 2 sitting around otherwise I'd choose the stage 1.
MOTOR: OEM 89 Shortblock, gt40P exploder heads with unknown valve springs until cam is decided, 1.6 rockers, tmoss ported lower and downs ford upper. BBK long tubes, and other supporting mods, I am shooting for the 300whp mark with my setup.
Will this cam clear? And more importantly will it make more power than the one if i can fit it.
88GTBLACK is offline
Old 09-30-2011, 10:07 PM
AdderMk2
Banned
AdderMk2's Avatar
check ptv
opinions are irrelevant.
AdderMk2 is offline
Dokilar
15
10-16-2015 08:13 PM
patchshaffer
Tuner Central
10-05-2015 02:24 PM
ChampInSD
10-02-2015 04:55 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
Quick Reply: TF stage2 cam clear ported gt40P's?
