1995 Mustang AOD to Manual Reverse Light Issue
I have a 1995 Mustang 5.0 that was converted from a AOD to a manual. The stock AOD harness is going to the trans i only have the speedo gear hooked up and a jumper wire for the neutral safety switch. I have no reverse lights now. i would like to make the car correct and change the harness to the transmission. Will a manual harness hook up correct with the main harness thats in this car? If its not a easy job i will just jump out the reverse wires and make a switch.
Diode Dynamics
28
05-26-2022 12:02 PM
