Need help with wiper motor replacement
Old 11-01-2011, 06:18 PM
bbbngowc
bbbngowc's Avatar
Default Need help with wiper motor replacement
Just got me a new wiper motor and proceeded to remove the old. Got the bolts out, but there's something else holding. Any idea how to take this motor off?
bbbngowc is offline
Old 11-01-2011, 06:31 PM
capri debris
capri debris's Avatar
Did you disconnect it from the arm inside the cowl?
capri debris is offline
Old 11-01-2011, 11:33 PM
bbbngowc
bbbngowc's Avatar
Ah, let me give that a go. Is it tricky to disconnect?
bbbngowc is offline
Old 11-02-2011, 09:03 AM
ALMOST STOCK
ALMOST STOCK's Avatar
Not tricky at all, the arm is held in place at the wiper motor with a clip.
Look inside the cowl area where the wiper motor comes through the firewall and you'll see the clip on the metal arm that goes to the wiper motor.
Whatever you do DO NOT lose the clip
ALMOST STOCK is offline
Old 11-06-2011, 06:50 PM
bbbngowc
bbbngowc's Avatar
Thanks. I was able to change it out today. Have wipers again. Whew!
bbbngowc is offline
Old 03-24-2022, 05:40 PM
Devanta1645
Devanta1645's Avatar
Default Wiper motor clip
Hey you guys sorry to bother you about this but how were you able to see the wiper motor clip I'm having trouble finding it and also what did you use to get it off ?
Devanta1645 is offline
Old 03-25-2022, 09:40 AM
ALMOST STOCK
Remove the cowl cover and you'll see it inside on the wiper arm. You may have to rotate the wiper arm so that the clip it's easy to remove.
Granatelli Sales
12-18-2015 06:22 PM
importsmasher
10-09-2015 04:42 PM
5.0 kevo
09-03-2015 06:24 PM
Hogquad
08-23-2015 05:26 AM
daytooday
08-16-2015 08:22 AM
Quick Reply: Need help with wiper motor replacement
