power stearing leak
Old 11-23-2011, 10:31 PM
Js88lx
Js88lx's Avatar
Default power stearing leak
wadup guys...? Well just another problem which is very minor. Now before you start asking, hey why dont you look up your question in search.., well i did but no one really had my issue. I have to re-fill my p/S pump once a week due to the metal line on P/S that actually swivels! Could i need a new line or O ring? How much is that line and can i get it at napa? Also if i change the line wont i need to bleed system? Thanks guys!
Js88lx is offline
Old 11-24-2011, 05:51 PM
mattdel
mattdel's Avatar
You need to take the line out, remove the plastic O-ring, replace it, then reinstall the line. To bleed the system, simply crank the steering wheel slowly, lock to lock, with the reservoir cap off.
mattdel is offline
Old 11-25-2011, 04:09 AM
Js88lx
Js88lx's Avatar
Nice., simple. Thanks
Js88lx is offline
Old 11-25-2011, 05:27 AM
eb2gt
eb2gt's Avatar
To answer your question about line. Yes you can get the line at NAPA. Go to napaonline.com and look it up. you can get the picture of the part the price and put the part on hold at your local store all on this web.
NAPA-know-how!!
eb2gt is offline
Old 11-25-2011, 12:23 PM
mustangGT86_05
mustangGT86_05's Avatar
Make sure you keep an eye on your level when you bleed it, of course. I normally bleed with cap on though, the pressure can surge back through the reservoir and squirt out. It shouldn't if you do it slow enough, but its just preventative, you can always remove the cap after you crank the wheel a couple times and see where you're at
mustangGT86_05 is offline
Old 11-25-2011, 09:12 PM
Js88lx
Js88lx's Avatar
yea well thanks for help guys! I replaced the 2 O'rings and parked home and noticed the puddle of p/s fluid,,,. putta.., so i payed more attention and noticed that the pressure hose where it meets the metal end closer to steering leaking... guess i need a new pressure hose!
Js88lx is offline
bconboy
09-24-2015 01:55 PM
trashxtrash
09-20-2015 10:49 PM
MusicCity615
09-12-2015 07:05 AM
Emblazoned
09-03-2015 10:45 PM
Quick Reply: power stearing leak
