Speedo question
its an automatic ?
how sure are you its accurate ? because i was pretty sure all fox body aod's are 8t drive, and its part of the output shaft so you can't just swap it without a 7t or 6t output shaft.
purple is AOD only and 21t, it's correct for 3.27 gears and 8t aod
both my aod cars were 8t, thats why i think that
Well I read a post somewhere on here about gears and it said with an AOD and 3:73s I would be going 75mph at 2500rpm. My speedo is dead on with that statement and while driving by a speed trap the local PD had set-up I was within a couple MPH of there radar.
i dont think you are correct.
how fast were you going ? I'm guessing you are 10% in error. about 5% per gear set is typical. so if you passed the radar at 35...then you'd be off only 3.5
but you might be...im just saying look into it more, if your next to a friend on the freeway see where yours and his are at like 75
thats a lot easier to tell then. or zero out your odometer and drive about 10 miles and see if your still hitting 100% on the mile markers
