KOEO/KOER test problem
I can't seem to pull any codes. I used a wire to jump the STI to the SigRTN pin.
My MIL light isn't working so I use a 12v test light in the STO pin but I am not getting any flashes.
When I turn the key over for the KOEO test I can hear the sensors which sounds like they activate for a second but I don't get any results from the light.
Same thing with the KOER test. The engine revs up twice like it is testing but the light doesn't flash.
I did test the light and it works fine, but I can't seem to retrieve any codes.
The reason I am doing this test is because the engine runs a little rough and I have ZERO engine vacuum. Its been like that since I got it. I can't find any apparent vacuum leaks so I am wondering if it is a bad intake gasket.
Anyhow, I did try jumping the STI straight to the negative post on the battery also, but still got no results.
Any ideas what might be wrong here and how I might be able to get these codes?
Sorry been busy. I found the reason for the vacuum issue. There was a hose missing on the back of the intake. The pevious owner had a piece of rubber over it to cap it off but it wasn't sealing. I couldn't hear the vacuum leak for some reason. Over the exhaust and fan spinning it is hard to hear anything.
Anyhow I'm now getting 18 inHG of vacuum.
I still can't get any codes from EEC though so I suspect the wiring or computer is bad. The previous owner did quite a hack job on the wiring so that could be it, but I have read a lot of posts online about these computers going bad and the engine still running but the EEC not putting out codes.
TfcCDR
09-14-2015 12:08 PM
dalefrancis88
09-11-2015 07:15 AM
09-08-2015 11:50 AM
