thermostat vs fan switch temp
Old 12-11-2011, 06:23 PM
302darrell
302darrell's Avatar
Lightbulb thermostat vs fan switch temp
ok i have a bone stock 95 gt 5 speed. factory fan will not come on. i replaced the factory temp switch to find out it still wont come on.. so i figured id buy a aftermarket fan temp controler. my main question is what temp should the fan come on at vs the thermostat temp ??.. car seems to hover around the 190 degree with the fan wired to a toggle switch. i was thinking a 200 degree temp fan relay switch.. but i want to make sure.. i can change the thermostat if 190 is too hot..
302darrell is offline
Old 12-11-2011, 06:47 PM
Bubba 95SN
Bubba 95SN's Avatar
CCRM by the radiator overflow is the fan controller. It is set to come on at 221*F. veryuseful.com has wiring diagrams in color.....
Bubba 95SN is offline
Old 12-11-2011, 06:54 PM
302darrell
302darrell's Avatar
sensor on the overflow lid?
Old 12-11-2011, 08:27 PM
302darrell
302darrell's Avatar
nvermind i know what you are talking about now.. its that little box thats mounted to that bracket.. after some digging i found out that it has to be a type "R" ccrm. even if it has the same part number it has to be a type "R" to work. so ima gonna call around to some junk yards to see if i can locate one in the morning.. hope it will make the factory temp gauge work too.. if not i can alway hook up the sunpro in a pod! thanks man!
Old 12-12-2011, 11:37 PM
Bubba 95SN
Bubba 95SN's Avatar
The temp sender is at front drivers side of intake single wire. Ground that wire and turn key on gauge should head to hot ..turn key off do not let it max. Need new sending unit if it does this and upper radiator hose feels hot after operating temperature. Advance has rebuilt unit for around $90(ccrm).
Old 12-13-2011, 12:30 AM
302darrell
302darrell's Avatar
i already replaced the temp sensor with a new one. i got a junkyard ccrm yesterday but i didnt have time to install it.. im so hoping that this ccrm fixes this electric fan issue.. did you know that you have to have the type R ccrm. even if its the same part number it has to be a type R to work on a gt. i dont think the one on the car is a type R. i just bought the car and im trying to fix everything the right way. back to factory.
Old 12-13-2011, 01:43 AM
muhstang1
muhstang1's Avatar
When I got my 94 GT the fuel pump hot was spliced w/ the taillights and the fan didn't work.
Toggle switch for the fuel pump and used the fog light switch for the fan......for about 6 months I ran it this way until I had a chance to do some research......eventually found someone who had a similar problem. After confirming their prob was fixed I used the same fix.....Now, the fuel pump was the PIP in the dizzy...but for whatever reason, the fan began working after dizzy replacement also. So, if someone knows why that would make a diff, maybe there is an possible angle there....
muhstang1 is offline
Old 12-13-2011, 07:10 AM
TrimDrip
FudgeDrip
TrimDrip's Avatar
I would figure that the computer may not think it needs the fan when it has been rigged up like that.
TrimDrip is offline
Old 12-13-2011, 11:25 AM
302darrell
302darrell's Avatar
well ****, i replaced the temp sensor for the fan. the factory gauge temp sensor, and the CCRM. still no fan.. whelp, looks like ill be using a aftermarket temperture fan switch. my car stays at 190 degrees. what aftermarket temperture fan switch do i need to get? thanks guys/ gals for all your help..
Old 12-13-2011, 06:26 PM
AdderMk2
Banned
AdderMk2's Avatar
perhaps instead of continuing to throw your money away, you should get a DVOM and do some wire probing.
If you would like to turn power on for the fan while testing to see where your problem is, you can disconnect the cars ECM.
If you were smart, you would stop pissing away your cash and start taking my advise.
AdderMk2 is offline
Quick Reply: thermostat vs fan switch temp
