yet another 3g idle charge thread. - MustangForums.com
Old 12-17-2011, 01:32 AM   #1
ITALIANO66669
Default yet another 3g idle charge thread.
ok guys.here we go.i been searching and there are alot of threads about 3g idle charge issues and no concrete answers.so heres the deal.90 mustang gt,3g alternator(dont know if its 95 or 130 amp)stock pullies,4 gauge feed wire,4 gauge ground wire.at idle,no accessories on 13.4-14.2 volt range at about 40 amps.turn on lights,radio,blower on high,foot on brake and defrost,12.4 volts80-90 amps.then using the alternator tester at work,at 2000 rpms.117 amps at 14.5 volts.now car has no ac so ac isnt on.im scared to add electric fans and ac system cause i dont wanna deal with killing the battery.also the battery is good.what is the fix to this?based on 117 amp max out out,does that mean i have the 95 amp pa performance alternator?would going to the 135 amp alternator fix this?do more amps mean more voltage?the d plug is correctly wired and the stator wire is correctly done as well.i have covered all the bases i can think of and have done alot of reading.thanks in advance.
ITALIANO66669 is offline   Reply With Quote
Old 12-17-2011, 02:47 PM   #2
mattdel
mattdel's Avatar
you're pulling 40 amps at idle with nothing on? jebus. i'd be lookin for whatever the frig is eatin so much power.
mattdel is offline   Reply With Quote
Old 12-17-2011, 10:21 PM   #3
Jfsram
Jfsram's Avatar
12.4 volts with everything on at idle will not kill your battery.
Really, is your car ever going to see those particular conditions for more than a few hours.
Even with the heavy draw from ac and electric fans. Those accessories cycle on and off and you probably drive 90% of the time above idle.
Jfsram is offline   Reply With Quote
Old 12-18-2011, 09:03 PM   #4
ITALIANO66669
this is true.but i have been out on rainy nights and it gets scary watching that guage drop and all.i have been doing more research and im wondering if maybe putting the pulley from the factory alternator onto this one would bring it back up.i do know what is on the alternator now is the pulley that pa performance puts on it.also based on the numbers presented,would this appear to be a 95 amp alternator?would i be better off with a 130?
Old 12-18-2011, 10:54 PM   #5
ITALIANO66669
heres another question for yall,where do yall have the fuse for the feed wire mounted?my area by the battery is crowded so im looking for a new spot to mount.
Old 12-18-2011, 11:11 PM   #6
Project 5.GO!
Project 5.GO!'s Avatar
I mounted mine below the air intake tube on the passenger side.
Project 5.GO! is offline   Reply With Quote
Old 12-19-2011, 08:30 AM   #7
Tony71502
Tony71502's Avatar
Never had a charging issue even with my accessories on.
My fuse is mounted inside my driver's side fender.
Tony71502 is offline   Reply With Quote
Old 12-19-2011, 11:00 PM   #8
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
+1 with what Mattdel said....
You are not gonna kill your battery though from adding everything. If you are worried though go through your car and upgrade your main grounds (battery to chassis and engine to chassis) and the main power wire. That alone will help with the charging on the car. Most of the time my gauge sits around the O and R on NORMAL and I have a STOCK alt running a Mark 8 fan, a small stereo system, and the headlights on. Yes at idle at a light it does tend to drop below half but most of the time and def while driving it is up there. But don't use some junk cheap *** battery though either.....
projectresto83 is offline   Reply With Quote
Intake manifold replacement Dokilar 4.6L (1996-2004 Modular) Mustang 15 10-16-2015 09:13 PM
TNT, New PB TCStangerv6 Street/Strip 12 10-11-2015 06:57 PM
Starting Issue svfetter 5.0L (1979-1995) Mustang 9 10-05-2015 12:39 PM
Vintage AC shop referral in los angeles bradleyb California Regional Chapter 0 10-01-2015 02:02 AM
Rough idle and vibrating 4cylinderplus2 V6 (1994-2004) Mustangs 9 09-30-2015 06:26 PM
155, 23, 90, 95, alternator, amp, amps, charging, ford, gt, idle, low, mustang, poor, volts
