driveshaft rubs?
Old 12-30-2011, 02:46 PM
Js88lx
Js88lx's Avatar
Originally Posted by Tony71502
Only a wrong tranny crossmember / hugely oversized tranny bushing would do that. But even still... a lot of people, including myself, run aluminum driveshafts which have a larger diameter than the stock steel driveshafts and do not have this issue. Something else is at work here, I think.
Is your floor dented/bashed up? Are you sure a shoddy exhaust isn't hitting the driveshaft? How do you KNOW that when the car is loaded with passengers(and I'm guessing you're not underneath to see, at this point) that the driveshaft is the problem? Can you see wear marks on the driveshaft where it is rubbing?
Well floor is not all crashed or bent but i can tell where the driveshaft end that goes into t5 is rubbing directly above on the trans tunnel! I can even see the scratches under the car on the tunnel. Im stuck on this one but just until i get under it.! HAHa
Js88lx is offline
Old 12-30-2011, 02:56 PM
Js88lx
Js88lx's Avatar
Originally Posted by enix187
the Parking brake bracket can come loose and allow it and the cables to run, does you parking brake handle lock in a really high position
Yes, it does! Son B barely locks (sometimes) and iv already adj my shoes?
Js88lx is offline
Old 12-31-2011, 10:06 PM
enix187
enix187's Avatar
I'll try my best to describe how to fix it, the thread I used had pictures but with a new computer comes lost webages. There is a bracket under the car just past the end of the tranny that secures the 1 - 2 cable setup for the parking brake. It was spot welded quite poorly by the factory and can snap right off, this bracket will run the driveshaft and when its bent will drag the cables down where they rub the driveshaft. There are a lot of ways to fix it but the most common thing is to drill some holes and use screws to re attach the bracket, then make a little plat to hold the cables up. I'll do some looking to see if I can find the article/thread that had all the pretty pictures
enix187 is offline
Old 01-02-2012, 06:25 PM
Js88lx
Js88lx's Avatar
sweeeeet!!! ill check it out on my next day off. Ill show you guys with piks!!
Js88lx is offline
mtgldr
02-03-2024 09:00 PM
baddog671
07-26-2016 01:20 PM
Boostaddict
2.3L Eco-Boost Tech
11-24-2015 06:11 AM
Matt's 95 Stang
10-05-2015 07:16 AM
ccdguy
09-19-2015 05:20 PM
Quick Reply: driveshaft rubs?
