hesitation/ falling on face
Old 01-05-2012, 12:34 AM
RTW0223
RTW0223's Avatar
Default hesitation/ falling on face
first off here's what i have done...
1992 5.0
gt40 heads
trickflow stage 1 cam
1.6 rr's
trickflow upper & lower intake
255 lph walbro fuelpump
holley adj fuel press regulator
new spark wires/distributor cap & rotor
70mm tb& egr spacer
fenderwell bbk cai
here's what's happening:
when cruising under 3k rpm and i go to step on the throttle there is severe hesitation. it;s like it falls on its face
has anyone with similar setup have this problem? i dont have a tune could it be that? could it be a part mismatch between the bore of the intake and heads?
RTW0223 is offline
Old 01-05-2012, 06:46 AM
mattdel
mattdel's Avatar
"falling on face" is almost always a very substantial drop in fuel volume/pressure. One of the more common culprits is the baffle in the fuel tank, but even a deadspot in the TPS could cause something similar. If you experience the same problem while taking hard right hand turns and trying to gun it out of the corner, it's likely the tank.
If not, you'll need to find yourself a friend with a nifty scanner and start some data logging.
mattdel is offline
Old 01-06-2012, 12:36 AM
RTW0223
RTW0223's Avatar
and to clarify, as there may be a multitude of similar meanings to 'falling on its face', i mean when im driving under 3k rpms and when i push the pedal to the floor, you'll hear the engine rev up as is should, however , the car does not move as it should. the tach will slowly but surely climb upwards. if that all makes sense. lets just say if i were to race from a 40 roll, im sure i would lose to a mini van
RTW0223 is offline
Old 01-06-2012, 01:17 AM
mattdel
mattdel's Avatar
Ok, that sounds like clogged cats to me. Got the stock h-pipe in there?
mattdel is offline
Old 01-06-2012, 09:55 AM
RTW0223
RTW0223's Avatar
no, it has long tubes, o/r h, to original 40s
RTW0223 is offline
dudeguy421
09-24-2015 11:16 AM
AMAlexLazarus
AmericanMuscle.com
09-23-2015 01:14 PM
2015Ecoboost
09-17-2015 01:48 PM
09-08-2015 04:35 PM
GimpyHSHS
08-29-2015 06:30 PM
Quick Reply: hesitation/ falling on face
