how do I tow/move my mustang thats stuck in gear?
Old 01-09-2012, 09:42 AM
jonny45601
jonny45601's Avatar
Default how do I tow/move my mustang thats stuck in gear?
I need to have my 89 Mustang Gt Auto towed to a friends house so we can replace the transmission but it's stuck in drive and won't go in neautral. How do I have it towed or can it be towed? Thanks for any help.
jonny45601 is offline
Old 01-09-2012, 01:32 PM
jimkaray
jimkaray's Avatar
depends on how you want it done. They can drag it up on a roll back with a winch, use a wheel lift, or hang it off a traditional 'hook' style sling. Or you can disconect the drive shaft and flat tow it with a buddy.
jimkaray is offline
Old 01-09-2012, 04:13 PM
Bubba 95SN
Bubba 95SN's Avatar
What he said.
Bubba 95SN is offline
Old 01-09-2012, 10:13 PM
ITALIANO66669
ITALIANO66669's Avatar
yep disconnect the driveshaft,get ready for the trans fluid to leak out then tow as neccessary.
ITALIANO66669 is offline
Old 01-09-2012, 10:29 PM
ColamanGT
ColamanGT's Avatar
Either disconnect the driveshaft from the differential, 4 bolts hold it on as said before, or flatbed. You can also try moving the shift linkage manually from under the car, on the drivers side. Push the lever that's pointing down, toward the engine. Should put it in park.
ColamanGT is offline
Old 01-09-2012, 11:00 PM
mattdel
mattdel's Avatar
Know what works real good? You know those wheel dolleys that they sell to roll cars around that are being resto'd? Stick one of those under the rear pumpkin, or buy two of them and use both rear wheels.
Don't forget, and I cannot stress this enough: Your rear wheels, obviously, are the "park" wheels. Don't leave the car sitting on a steep incline or anything like that, unless the driveline is hooked up and the rear wheels are on the ground.
mattdel is offline
Old 01-10-2012, 07:38 AM
Tony71502
Tony71502's Avatar
Just have a tow truck lift up your rear and tow you that way. Pretty simple. Make sure he's careful on bumps, don't want to mess up those lovely GT bumpers.
Tony71502 is offline
Old 01-10-2012, 05:48 PM
ITALIANO66669
i didnt think about popping the linkage off to put in neutral.i actually did that to someones car once.some douche blocked me in at a fair so i did that and moved that sum bitch.i didnt even bother putting it back on.sorry to get off topic but i had that thought.lol
Old 01-11-2012, 07:19 AM
Tony71502
Tony71502's Avatar
If the transmission is locked up, removing the linkage does nothing except let you change the shifter position.
Old 01-12-2012, 09:27 PM
Project 5.GO!
Project 5.GO!'s Avatar
Oh, that is hillarious!! Imagine the fun if we combined this story with the cautionary tale obout the steep inclines, and possibly a lake or a septic tank pump truck, for good measure.
Project 5.GO! is offline
djbigskrilla
09-20-2022 01:04 AM
landomar2014
08-17-2015 04:27 PM
daytooday
08-11-2015 09:22 AM
landomar2014
08-11-2015 06:39 AM
dseg
AmericanMuscle.com
08-10-2015 03:29 PM
Quick Reply: how do I tow/move my mustang thats stuck in gear?
