Throttle body with GT40P Intake Manifold
Old 01-27-2012, 01:05 PM
yurizx6r
yurizx6r's Avatar
Default Throttle body with GT40P Intake Manifold
I was just wondering what throttle body I need to use for my 90 GT when I switch out my intake manifold with the GT40P upper and lower intake manifold. I got the parts off a 97 Explorer, and I'm cleaning them up; I also got the throttle body from the Explorer just in case I needed it. My current TB has a hole in it because the owner who had it before me NOS'd the car. Should I buy a new 70mm one, go with a used stock, or do I actually need to use the one from the Explorer? Which will fit? Thanks for any help or advice!
yurizx6r is offline
Old 01-27-2012, 01:16 PM
my77stang
my77stang's Avatar
with a little fabbing it will hook right up. I had to tack the linkage arm from the stock TB on the explorer TB. Then I had to slot the holes in the TPS so it would bolt onto the explorer TB. I also had to grind a very small amount off the throttle shaft because it was too tall to properly use the TPS from the fox.
Really all in all it took me 30 minutes to fab it up and now it looks as completely factory.
my77stang is offline
Luke9222
10-22-2015 11:55 PM
94stangnewbe
V6 General Discussion
09-07-2015 07:39 PM
Webster454
09-07-2015 04:59 AM
Mustangmalo
09-06-2015 05:22 PM
Quick Reply: Throttle body with GT40P Intake Manifold
