Possible spun bearing?
Old 02-03-2012, 01:51 AM
  #21
danielcast1
danielcast1's Avatar
So things to check, I'm trying my hardest to avoid pulling the engine but I'ma bite the wrench here and do it all over again, I let the anxiety get the best of me. Thanks guys I'll post what the problem was when I get it fixed.
1. Feed tube
2. New oil pump (why not)
3. Lifters?
4. I'll check my radiator
danielcast1 is offline
Old 02-03-2012, 01:53 AM
  #22
danielcast1
Btw my phone is loading these responses in mismatched order so sorry if it confused y'all and the feed line is in the oil pan?
Old 02-03-2012, 01:57 AM
  #23
Project 5.GO!
Project 5.GO!'s Avatar
Runs from the oil pump down into the pan. Good luck, and replace that reservoir too! lol
Project 5.GO! is offline
Old 02-03-2012, 02:10 AM
  #24
mustangGT86_05
mustangGT86_05's Avatar
Lifters wont show you anything as far as oil pickup or pressure, but my concern on them is if you ran them dry, especially under load to accelerate as much as you did, that damage occured. Checking the pickup tube will cost you an oil pan gasket, just do not force the pan off, they can be tricky. Also I am not entirely sure how the oil pumps on 5.0s are driven but if its shaft driven which I am pretty sure it is, its possible the shaft is broke or not set right and not driving the oil pump.
mustangGT86_05 is offline
Old 02-03-2012, 03:05 AM
  #25
Project 5.GO!
Its shaft driven.
6bangr
02-15-2016 07:40 AM
KingRando
10-02-2015 08:06 AM
Offendant
09-23-2015 07:21 PM
ctgreddy
09-20-2015 08:35 PM
ccdguy
09-19-2015 05:20 PM
Quick Reply: Possible spun bearing?
