Rough idle at 2-3000 rpm
I recently replace my 5.0L with a 347 stroker in my 1991 GT. The engine description from the builder is:
Stock block, 0.030 over, SRP Pistons, Scat Rods and Crank
about 9.5:1 compression, balanced,SFI Damper
Patriot Aluminum 185cc heads with a little port work, Roller rockers, 280 HR comp Cam, TFS Track Heat Intake, 24# Injectors, 70mm BBK Throttle body.
The engine was installed, including long tube headers, and was running great! However, the car was then taken to a different shop to have a strut tower brace, intake tube and exhaust installed, as well as a wheel alignment. While at this shop they welded on the intake tube and the exhaust pipe due to the headers.
We then got the car back with all of this installed and it runs like absolute crap now. At idle it is not too bad, but when taken to 2-3000 rpm it starts sputtering and popping and the tac bounces when this misfiring is happening.
They have replaced the plugs, wires, cap, rotor, distributor, MAF, we have even tryed a new (not 100% new but from a different car) PCM.
I have an engine wiring harness and a rebuilt PCM on order with fingers crossed it will cause this gremlin to go away.
If anyone has any comments/ideas I would appreciate it.
Thanks
Thanks
Thanks for the responses.
We are doubting they disconnected the battery when welding. That seems to be accepted at the culprit, but trying to find what got fried from that is frustrating (and expensive).
I dont know what else to try before we take it to some electrical "specialist".
Oh, the plot thickens. You would be suprised what a call from a lawyer can do. I would get an estimate from an indy shop and go from there. Keep track of all your reciepts. I'm not one to play the sue card, but in this case I think I would persue it. Don't cost anything to try.. Good luck, I hope you get it resolved.
