94 rear axles 2 a fox?
Old 02-10-2012, 09:21 AM
DaBears1983
DaBears1983's Avatar
Default 94 rear axles 2 a fox?
So i m gonna be headed to the yard again for the rear discs on a 94...I was told that the rear axles might be a diff spline count...looked around all I found was if I used the rears the width would be about 1\4" wider on each side...will they work than? Kinda confused cause another fella said to double check...oh the 94 is a V6 thank for your help guys
DaBears1983 is offline
Old 02-10-2012, 04:47 PM
AdderMk2
Banned
AdderMk2's Avatar
the v6 has a 7.5" rear end, which actually still uses 28 spline axles.
SN-95 axles are 3/4" longer (so thats a total width addition of 1.5" over the fox axle width)
Why dont you just pull an entire axle from a GT?
AdderMk2 is offline
Old 02-10-2012, 06:11 PM
DaBears1983
The yard that's here doesnt have any gt's. So I should grab the hub assemblys and prob axles from a ranger or such?
Old 02-10-2012, 06:56 PM
AdderMk2
Banned
AdderMk2's Avatar
ranger hubs wont work for you
you will need to find axles from an old ranger. year is very important.
If you cant find a 94-98 GT in a junkyard, you need to find a new place to look. Search on www.car-part.com
AdderMk2 is offline
Old 02-10-2012, 09:03 PM
mustangGT86_05
mustangGT86_05's Avatar
Or hell, check craigslist, I know here there are lots of mustang parts or people parting out cars
mustangGT86_05 is offline
Old 02-10-2012, 09:15 PM
DaBears1983
Ok how about the hubs off the 94 v6 and the ranger axles?
Old 02-11-2012, 06:57 AM
AdderMk2
Banned
AdderMk2's Avatar
*facepalm*
AdderMk2 is offline
Old 02-11-2012, 08:48 AM
DaBears1983
lol i feel the same way!! the tech sticky says ranger axles and sn95 disc will work but others say diff... im just try to get disc all the way around and keep my stocktrack width lol thanks again and sry for sounding noob-ish
Old 02-11-2012, 09:12 AM
mustangGT86_05
If I remember right the caliper brackets on the sn95s will not line up correctly for "stock track width". I normally see people use the ranger axle shafts for a 5 lug conversion while keeping the drum set up. Others for a disc swap mill down their caliper brackets or you can buy some for a hefty price. This is all going on what I've found online though
Old 02-11-2012, 09:27 AM
AdderMk2
Banned
AdderMk2's Avatar
im just try to get disc all the way around and keep my stock track width
you cant, with junkyard parts. If you were willing to spend about $600 on brackets, I could point you in the right direction... but IMHO, your best move would be to buy some SN-95 front spindles, 99+ gt calipers and brackets, A-R-B axles, 10" drums/backing plates/wheel cylinders/shoes/hardware (ranger)
You dont NEED rear disc brakes... you are just getting greedy.
AdderMk2 is offline
Quick Reply: 94 rear axles 2 a fox?
