code 34? egr valve or sensor
Old 02-15-2012, 10:12 AM
9165pt0
9165pt0's Avatar
Default code 34? egr valve or sensor
hey guys you may have seen im having idle issues. just had a ? on code 34. bad egr valve or sensor? i applied vacuum to egr valve while at idle and nothin changed.
9165pt0 is offline
Old 02-15-2012, 10:48 AM
AdderMk2
Banned
AdderMk2's Avatar
if you apply vac to the EGR and the car doesnt stall out, your lines are likely caked with carbon. Remove the EGR and make sure it is not clogged. After that you would remove the EGR spacer fron behind the TB and clean it, followed by removing the intake manifold and doing the same.
AdderMk2 is offline
Old 02-15-2012, 07:33 PM
9165pt0
9165pt0's Avatar
ya it didnt stumble. i have the egr off right now and am cleaning it. which lines are you reffering to? also ill clean the spacer, and the intake looks like it has a lot of black gunk in it. but its a gt40 tubular, has always been a pain to clean. any ideas?
9165pt0 is offline
Old 02-15-2012, 07:52 PM
AdderMk2
Banned
AdderMk2's Avatar
Berrymans B12 Chemtool and some soak time...
AdderMk2 is offline
Old 02-15-2012, 08:41 PM
9165pt0
9165pt0's Avatar
ok thanks adder. pullin off intake right now. hey im confused as to the egr piping? i see 2 lil rubber hoses go from egr spacer into a black pipe. i popped the hose off and the pipe has coolant in it and i believe goes into the water pump.which pipes? thanks
9165pt0 is offline
Old 02-15-2012, 09:28 PM
AdderMk2
Banned
AdderMk2's Avatar
did I mention piping?
I dont think I did...
AdderMk2 is offline
Old 02-16-2012, 11:29 PM
9165pt0
9165pt0's Avatar
oh i must have read it in another thread. but ya i got some berrymans and cleaned the crap out of everything. hopefully ill have time to put everything back together this weekend and give a positive update. thanks
9165pt0 is offline
Old 02-25-2012, 07:58 PM
9165pt0
9165pt0's Avatar
Default UPDATE
ok so i havent been able to work on mustang until now. i checked and cleaned everything.timing is at 12 degrees. no vac leaks, although i saw the vac guage go from 17in at idle and drop down to 12in for a little bit. really wierd. still idles so rough, like its gasping for air. i took it for a spin and at a stop light it will idle fine. wierd. if i give it 3/4 throttle runs perfect, if i floor it from about 2000rpm itll stumble and i hear popping noises. i came home, ran codes koeo 10, 34. koer 12 41 91. im frustrated beyond belief. plz help.
9165pt0 is offline
Old 02-25-2012, 07:59 PM
9165pt0
9165pt0's Avatar
oh i forgot, once i cleaned egr valve and passage into intake, it does stumble if i apply vacuum to the valve at idle.
9165pt0 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
jwog666
12-27-2021 08:09 PM
mrtrodonet
09-19-2020 03:12 PM
Dathan
10-05-2015 05:52 AM
ChampInSD
10-02-2015 04:55 AM
Quick Reply: code 34? egr valve or sensor
