Tire Rub
Old 02-19-2012, 07:05 PM
89StangGTConvertible
89StangGTConvertible's Avatar
Originally Posted by AdderMk2
Your car has some pretty severe suspension problems. If I were you I'd remove the spacers. You might want to bring your car to an alignment shop. Can you post a picture of your car from the side, with the wheels straight?
Also, you clearly know nothing about tire sizing. Please go do some reseach (google how to read tire sizes). A 225/55/16 is a 25.7" tire, which is stock (correct).
The "stock" tires for 1987-1989 GT's are actually 225/55/15's (they fit on the 15x7 turbine wheels)they were not 225/55/16's, as you mention. Ford made the wheel-well wider from 91-93 to accommodate 16" wheels. From 91-93 the stock tires were 225/55/16's on 16x7 wheels. My car is in near-mint condition, with 62,021 miles on her. I do not have "severe suspension problems", LOL!. You came to that conclusion by looking at the pic I posted!?! At any rate, I've done some additional research, and it seems 225/55/16 tires in the front, as you mentioned, will indeed solve this very common rubbing issue with the wider tires. I have a pair on order. Thanks!
89StangGTConvertible is offline
Old 02-19-2012, 07:13 PM
Originally Posted by mjr46
Eric the middle number is the sidewall height, if you went with a 225/50/16, it may give it the dragster effect = higher in the back , lower in the front to balance it out addermk2 is right a 225/55/16 would be the first place to start, however, let me check my rack at the shop, I may have a 225/55/16 we could use as a test tire the next time you come up
Thanks, Mike, but I just ordered the 225/55/16 tires for the front. I am certain (after much research) that this tire size will be the fix. Next time I come to the shop, we'll be spending our precious time on "go fast" mods!!!
Old 02-19-2012, 07:25 PM
1989 GT KY
1989 GT KY's Avatar
I was under the impression that the second number was the sidewall height (i.e. 55 mm?) The first being the tread width, third the I.D. in inches.? Also, I've read that the "pre '90" Mustangs has a smaller front fender opening. Not sure if either of these bits of information are correct..
1989 GT KY is offline
Old 02-19-2012, 07:31 PM
You are right, from 91-93 the wheel-wells were made bigger by Ford to accommodate 16" wheels.
Old 02-19-2012, 07:55 PM
Cool
hey, go easy on him....and if you read, the spacers are there so he could get the center caps to go on, the grease fittings interfere with the caps with out the spacers, that is the only reason they are on there, and the wheel still hit before the spacer was installed just not as bad, Had we had time last night we'd of thrown it on the alignment rack to make sure all is set right, but from having "once" overed the car, there does not appear to be any suspension issues not does it looked like anyone has ever touched the settings as the factory rivits in the strut plates are still in place and his car has 60k on it, very well taken care of......the problem appears to be the "gumbo" donut wheels/tires he has.....awful lot of sidewall on them, my 245/50/16's I had were no where near like his, you can have 3 of the same size side by side and have large variances between different makes
Ok, "gumbo" donut tires made me laugh... it's true, though. These tires, which I ordered from American Muscle, are insanely wide for some odd a$$ reason!
Old 02-19-2012, 08:49 PM
AdderMk2
Banned
AdderMk2's Avatar
And just to add, Here is an ebay auction for a set of Goodyear tires that were probably OEM equipped onto a late 80's mustang with 15x7" stock wheels
http://www.ebay.com/itm/85-86-87-88-...653064&vxp=mtr
also, have you ever even seen a 225/55/15 tire? I've been working in the automotive industry for a long time and I still have yet to actually SEE a set. I don't get very many chances to get out to the races to look at Hoosier wet track tires...
AdderMk2 is offline
Old 02-19-2012, 08:57 PM
1989 GT KY
1989 GT KY's Avatar
YAWN................
Old 02-19-2012, 09:06 PM
I love foxbody mustangs , I wish I owned one
You clearly have some serious anger issues that you should work out with a licensed professional. I will not dignify your rants with a reply. PS - had you clicked on my "garage", you would have see a picture of my car from the side (and the severe suspension damage). Going forward, I ask that you please refrain from "helping me" on any future posts that I may make. Many thanks.
Old 02-19-2012, 09:56 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Mike, If the wheels don't fit because of the grease caps, you CAN leave them off. OR you could find a set that fit behind the wheels. In his situation, you don't have to worry about crap getting into the bearings because his wheel would seal enough against the rotor.
WOULD YOU LIKE TO BE ON PA FOR A WHILE KEITH DO YOU NEED A TIME OUT?? Keith, let me make this short and simple, if he had wanted to buy new caps, he would of, he wanted to use what he had so I gave him the alternative........ever think that what he had may have been a gift from a special person to him and therefore that's why he wanted to use them at whatever cost??? Next time before you go on yet another rant, you'd better have all the facts. I'm done cleaning up after your messes and this is the final straw, one more spat or complaint about you and I'm sure admin will be happy to give you the permanent boot, unbeknownst to you I've saved you from that more than once. Enough said.....please to the rest keep the thread on track
mjr46 is offline
jwog666
12-27-2021 08:09 PM
CS2007
06-25-2019 09:45 PM
KingRando
10-02-2015 08:06 AM
marc954
09-29-2015 11:18 AM
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
Quick Reply: Tire Rub
